I_am_still_wayn
Jan 07, 2014Explorer
I have a 2012 Airstream Avenue Suite built on a 2011 Chevrolet 3500 Van. The actual weights with full water and propane, two batteries, empty holding tanks, and completely stocked with food, clothes, pots, pans, etc. and outfitted for use with chairs, table, grill, leveling blocks, etc. are as follows:
1. Actual overall weight is 9000 lbs. The GVWR is 9600 lbs.
2. The front axle actual weight is 3900 lbs. The GAWR is 4300 lbs.
3. The rear axle actual weight is 5100 lbs. The GAWR is 6084 lbs.
4. According to Airstream, the CCC is 1382 lbs.
5. According to Chevrolet, the GCWR is 16000 lbs.
I hope this helps.
To the OP: I sent you a private message.
I hope this helps.
38,782 PostsLatest Activity: Aug 31, 2026
