The Garnet system will require you to run 14 or 16 gauge wires. The Aladdin system wires are not the same as they are Phone (communication) type cables and are not large enough gauge to use the Garnet system. The Garnet system requires dedicated wires for the sensors. You only have 2 wires that go from all 3 tanks to the Garnet panel. ALL 3 tank blue wires go together and then 1 wire goes to the Garnet panel. All 3 Black sensor wires(ground) are also connected together and then just 1 feed ground wire goes to the remote. Unless you are set on an inside panel, you can install the system in the wet bay to not have to run the wires inside the motorhome. Doug
