Dutch_12078 wrote:
The SeeLevel installation guide calls for 18 gauge wire and it works fine with the wiring used for the common KIB screw sensors. The SeeLevel sensors can be grounded at the tank end, requiring just a single wire to connect all the sensors to the dislay.
Model 709 Manual (Page 14)
He does not have a KIB type system. So, he does not have the wiring used on a KIB system. I state 14 or 16 gauge wire because it is easier to run and is better over the long term. That is why I use when installing a Garnet system that does not have existing correct wiring. Doug
