KevinE wrote:
Mine will give the alarm when you are in gear and the parking brake is still set as a safety. It will also sound if the brake is released and I'm in neutral, again as a safety. If it's going off when you're in gear and brake released, I'd suspect an air switch on the parking brake that has gone bad. Does the park brake light on the dash go out when released?
Mine will continue to sound the alarm no matter what combination I try of putting the brake on and off, putting the transmission in drive or reverse. The ONLY WAY to get the stupid thing to go off is to put the transmission in NEUTRAL. Then it stops almost immediately.
It doesn't matter if the air brake is set or not. If it's in neutral it stops beeping. As soon as you put it in gear it starts beeping again.
