JaxDad wrote:
Sometimes the answer isn’t to the question you’re asking.
Are you SURE it’s an air alarm? Not an alarm telling you that one (or more) of the levelling jacks aren’t fully up?
My ‘jacks down’ alarm only sounds when you put the transmission in drive or reverse.
I'm not saying it is an air alarm issue. But the alarm that is beeping is the SAME ONE that the low air pressure uses. Same sound. It's loud enough to hear in the next county. It could be a jacks down warning but the hydraulic leveling system is off, shows no lights, and raised the jacks automatically on it's own so they should be all the way up. I'll check that tomorrow. Thanks.
