bill257 wrote:
I do not have access to the tank from inside.Only way to get the bleach in to the tank is through external water filling outlet.Now what is the best way to get the bleach in the fresh water tank.I mean should I have to connect a pipe to external filling hole and pour bleach with hand or there is another way to do it.
I have a coachmen Class C also, so I assume the water fill is like yours. I poured some bleach into the fill hose then attached it to the camper water fill and the other end to the house spigot,then turned the water on. Worked pretty good. Gary
