DSDP Don wrote:
"elhajj33"......We need some more info. When does it pull right. Have you found a flat road, no road crown, and tested the coach. Does it pull hard? Does it just drift?
If it's just a slight pull and it does it on flat level ground, often it can be a tire. I sold tires for several years and sometimes you just couldn't get a vehicle to stop pulling. Simply swap the two front tires and see what happens. This will very often resolve the issue, especially if everything is set to specs.
Before I took it in, the pull was pretty drastic to where i had to hold the steering wheel to the left to keep it pointing straight.
after the first alignment, it got a lot better, but it was still drifting to the right. The test roads were chosen by the josam techs. They were known flat to them and they know how they feel better than me. Two separate techs said "yah, it still goes right" I was also told "1 percent of the vehicles we see don't track straight unless they put a safe-t plus on it and, unfortunately, yours is one of them"
The did try swapping the wheel right to left to see if that would address the issue, but it did not.
In terms of how drastic, i definitely always feel like i have to keep correcting left. It's definitely a drift not an all-out pull, but it certainly feels like effort to keep it pointing straight.
