B_s_Bunch
Feb 25, 2014Explorer
rgatijnet1 wrote:I see a lot of semi trailers going down the road that look like the trailer is trying to pass the tractor.:E axels not aligned. Larry03 RoadKing wrote:Bumpyroad wrote:
I just got new tires. ran up the street and had 4 wheel alignment done.
bumpy
You got a 4 wheel alignment on a motor home?????
Yep, aligning the rear axle is called the thrust angle alignment and makes sure that all four wheels are going in a straight line and square to each other. As seen from the rear, if a vehicle's rear axle is out of alignment the vehicle looks like it is crabbing down the road. Adjusting and aligning the rear axle eliminates this crabbing and results in better rear tire wear and better handling for the coach.
38,780 PostsLatest Activity: Aug 05, 2026
