OFDPOS
Sep 15, 2017Explorer
klutchdust wrote:
Koni RV shocks added to mine, pricey but took the "roll" out of it and most if not all the big rig sway when they pass. And that severe banging over RR tracks and the like, gone....
So did you do Koni's or Bilstein shocks ? I've read a few of your posts and you have commented you replaced with both.
5/17/17 you posted :
Heavy duty sway bars,bilstein shocks and wheel alignment did it for my 30Ft. Cambria. Also that teeth grinding pounding when going over tracks or bumps is minimal. If you buy cheap shocks nothing will change, based on what I have read on these forums. Also air pressure, keep after that.
I know I've posted on several threads here on the Koni shocks and felt they were a waste of money on the front , but were good on the rear.
If I had it to do over I'd stay with Bilstein's HD front and rear.
As to the OP
If you haven't yet? Replace that undersize front anti sway bar !
With a Hellwig , you'll really notice the difference..
38,778 PostsLatest Activity: Jun 06, 2026
