There must be a User Profile: Senior -or- RV = Mount Offensive. Senior -Plus- RV = Full On Assault.
For you lurkers: It's cheaper to buy a whole take-off front end from an outfit that converts Ford Chassis to 4x4 and install/have installed than it is to do a complete front end overhaul (ball joints, axle and radius bushings) or a complete brake overhaul (Rotors, Calipers, Pads) than to have those done part-by-part. And, if your chassis is 2007 or earlier, you get the newer 2008 and later brakes which are far better.
