- FlanzExplorer
DSDP Don wrote:
Flanz....Here you go.....DEF
And again....DEF
I guess you could have done this.....
You're correct, I could have, but since I don't use DEF I was just curious and figured someone else had already done it.
Thanks for providing the info. When I do purchase a DP this will be one thing I don't have to go searching for....
-paul - wallynmExplorerAll the same except the DEF that I personally produce and then it depends on how much beer I drank for the %age of urea content.
- nevadanickExplorerLight and heat are its enemy. I have ran several different brands in my GMC.
- Bob___AnnExplorer
Flanz wrote:
Bob & Ann wrote:
It is said to be the same which I believe that it is. What is important is that it is fresh as it does not have a long shelf life. It also breaks down quicker in hot climates.
Is there a date code on the bottle/container? Do you have something that states it breaks down quicker in hotter climates? Please provide a site that claims this since I've never seen this.
-paul
It is published everywhere. Just do a search.
Diesel Exhaust Fluid, otherwise known as automotive-grade urea, is a very stable product with a comparatively long shelf life. According to industry sources:
DEF storage containers from Terra IndustriesDEF storage containers from Terra Industries
• If Diesel Exhaust Fluid is kept to temperatures between 10 and 90 degrees Fahrenheit, it will last a minimum of 1 year without problems.
• Big bulk dispensers (1,000 gallons) have internal climate control systems.
• In cold temperature regions it is recommended to store Diesel Exhaust Fluid in a storage unit. In warm temperature regions it is recommended to store Diesel Exhaust Fluid in a shaded area.
• New climate control systems specifically for Diesel Exhaust Fluid are being developed. - DSDP_DonExplorer
- FlanzExplorer
-paul - Bob___AnnExplorerIt is said to be the same which I believe that it is. What is important is that it is fresh as it does not have a long shelf life. It also breaks down quicker in hot climates.
- dubdub07ExplorerI guess so. I have not had to think about it until now. I just buy the cheapest.
- DavisKExplorerIt's supposed to be the same to meet government standards. According to my owner's manual, if poor quality DEF is used the driver info center will display the following message:
"EXHAUST FLUID QUALITY POOR - SEE OWNERS MANUAL NOW – 160 KM (99 MI) UNTIL 105 KM/H (65 MPH) MAX SPEED"
38,783 PostsLatest Activity: Sep 09, 2026
