woodhog's avatar
woodhog
Allegro 30 foot 1985
We are working on an older 1985 Allegro 30 footer, it would appear that
the passenger side seat needs to be removed in order to lift the doghouse
cover , it hinges in the front and lifts upwards from the back after releasing
a hold down clip, I think !!
Any help is appreciated..
  • woodhog wrote:
    Success!!
    As noted above, we had to rotate the passenger side seat so it was facing the side window, seat back then was extended to the full
    Upright position.
    The dog house cover then had room to be raised up between the
    Two seats.
    It hinges at the dash and when raised gives good access to the top of the engine.
    There are spots that I dont think could ever
    be reached.
    Looking for the oil dipstick on the big 454 gasser
    Now.. !!
    It's a LONG dipstick. My old one was from the front.
  • Wow this brings back a lot memories. I had a 1985 28' for 19 years. Sometimes I wish I still had it, I had so few problems with it.
  • Success!!
    Upright position.
    Two seats.
    be reached.
    Now.. !!
  • MrWizard wrote:
    i'm surprised the seat doesn't slide back enough or turn out of the way
    also it might be lift, then push back/toward the front of RV
    to unhook, then turn sideways to remove
    I agree. It doesn't sound right that you would have to remove a seat to open the engine cover.
    I would try to push, wiggle, twist or whatever it takes to get the cover open.
    I have heard of some that had hidden screws holding the cover in addition to the latches. (Maybe it was something a previous owner did?)
    When you get open, let us know how you did it?
    I really like the older Allegro's. :C
  • i'm surprised the seat doesn't slide back enough or turn out of the way
