I know this topic has been covered in the past, but I can't seem to find the right answer. I am planning a change over to Transynd using the double drain and fill method. For the first drain and fill,...
When I did my old class A. The trans took about 10 qts. When you remove the trans filter. DO NOT LOOSE the MAGNETIC WASHERS. Clean them and replace them on the stud.
