Vegas1
Apr 09, 2014Explorer
Allison 1000
I know this topic has been covered in the past, but I can't seem to find the right answer. I am planning a change over to Transynd using the double drain and fill method. For the first drain and fill,...
fredbon wrote:ArchHoagland wrote:
I haven't switched to Transynd because I can get a case of Dexron iii for $20 at Costco.
I do my own changes so it's cheap and easy.
Check out the fluid you are using, Allison has dropped Dextron III from the approved listings, seems the formula has been changed.
Fred
