JR45
Jun 28, 2016Explorer
Have you changed the trans filters or checked the level. Here is the way to check trans when you come in warm and after you get it level. (Checking Fluid Level with the Keypad)
The following procedure will allow you to check your transmission fluid level from inside the vehicle, and it is also more accurate than checking via the dipstick.
To enter the transmission oil level display mode, press the UP and DOWN arrow buttons simultaneously on the mode selector. A two-minute countdown begins when the following conditions are met:
Engine is at idle
Transmission sump oil is at operating temperature
Transmission output shaft has stopped
Transmission is in neutral
Oil level sensor is functioning properly
The display should show *8 and then count down to 0. Note that it will take two minutes to complete this countdown. During the countdown, the display flashes and a count (8,7,6,5,4,3,2,1) occurs reducing by one digit every 15 seconds.
NOTE: Failure to meet any of the above conditions will stop the two minute countdown. The shift selector will then display one of the following Oil Level Codes to show the reason for the countdown interruption. The countdown will resume where it stopped once all conditions have been met. Shift selectors with single digit display will display the codes one digit at a time. Shift selectors with two digit displays will display the codes two digits at a time.
OIL LEVEL CODE
CODE DESCRIPTION
oL 0X
Setting time too short
oL 50
Engine RPM too low
oL 59
Engine RPM too high
oL 65
Neutral not selected
oL 70
Sump fluid temperature too low
oL 79
Sump fluid temperature too high
oL 89
Output shaft rotation detected
oL 95
Oil level sensor failed
After the two minute countdown, the shift selector displays the oil level data as in the following examples:
OIL LEVEL READINGS
MEANING OF READINGS
o, L, o, K
Fluid level is correct
o, L, L, o, 1 or OL, LO, 01
Fluid level is 1 quart low
o, L, H, 1 or OL, HI, 01
Fluid level is 1 quart high
To exit the oil level display mode, press the NEUTRAL button or simultaneously press the UP and DOWN arrows twice.
JR
Engine is at idle
OIL LEVEL CODE
CODE DESCRIPTION
oL 0X
oL 50
Engine RPM too low
oL 59
Engine RPM too high
oL 65
oL 70
oL 79
oL 89
oL 95
OIL LEVEL READINGS
MEANING OF READINGS
o, L, o, K
JR
