ncrowley
Jul 25, 2016Explorer II
I brought the coach to my local Freightliner shop and found out the issue. The high pressure oil pump (HEUI) was going bad. This supposedly is something that sometimes happens in the Cat C7 engines. The problem is that when it is going, most of the time it puts metal shavings into the oil and into the injectors, requiring that the injectors be replaced.
The engine only has 40K miles on it when I purchased it at 8 years old, it had only 12K miles on it and I did not have past maintenance history records. That is why I purchased an extended warrantee.
This was an expensive repair - $5600. Thank goodness I purchased an extended warrantee when I purchased the coach and they paid for the repair. The warrantee has more than paid for itself at this point and I have about a year left on it.
So if you are having issues with the engine not responding to the throttle, you should go have it checked out. At some point, it would have failed completely and I would have been stuck on the side of the road.
