luvlabs
Jul 20, 2013Explorer
Tiffin uses 3 Allison transmissions with their motorhomes. The 3000 is used in the Phaeton, and Allegro Bus lines, the 2500 is used in the Allegro Red series, and the Breeze started out with the 1000 but it has been upgraded to the 2100.
Hope that ends all of the speculation on which transmission.
To the OP, lockout usually refers to overdrive. If the transmission is hunting back and forth between 5th and 6th for example, you can lock out 6th gear and hold it in 5th.
