williamp321ExplorerAug 11, 2014Allison TranI have erratic shifting with my 8.1 Allison 1000 tran. 50mph and above my tack shows 2200 to 2500 up and down from my tran shifting. Any one else every had this problem with this Allison 1000 tran.
wa8yxmExplorer IIIAug 11, 2014Yup, turn off overdrive when it does that.. This can happen if you are towing and hit just the right combo of grade and weight and headwind and such.Also, the suggestion of routine service is a good one.
Related ContentAllison TransAllison HD 4060 Trans Code?Allison tran key pad issuesNew GM HD "Allison" trans not built by Allisonallison trans
