map40ExplorerAug 26, 2021Allison Transmission leakMy 2000 Safari Sahara has a couple of small leaks in the bolts. One on a drain bolt and another one on the bolts on the front. Suggestions? Just try to tighten them up a little? Show More
wolfe10ExplorerAug 26, 2021Sorry, but I am not able to view the images.Is the leaking bolts the ones that hold the filter covers? If so, absolutely, only apply the torque specified in the Allison filter kit instructions.I don't have them in front of me but recall it is more than 45 inch-lbs. But the caution about over-torquing steel bolts in to aluminum is right on.
Related ContentAllison TransmissionAllison 3000 transmissionAllison 3000 transmissionallison transmissionAllison Transmission
