rgatijnet1
Oct 12, 2016Explorer III
The only way your Allison transmission would up shift is if the grade changed or if you were trying to accelerate and then let off of the throttle because you were happy with the speed. In that case, it would revert to the best gear to maintain that speed with the load. It would not up shift in to a higher gear if it could not maintain that speed because of the load and incline.
