Tom_Barb
Sep 07, 2013Explorer II
sch911 wrote:Tom/Barb wrote:
Limp mode normally reduces the pressures in all circuits.
Have the ECM rebooted, and allow the transmission to return to normal mode.
over heating the tranny once should not ruin it. but it will place it in limp mode.
try it, what do you have to loose?
One occurrence of limp mode induced by extended city traffic should not trash the tranny. I agree with this post. Clear the codes, reset the TCM and drive it.
I would also have the transmission drained and flushed and the filters changed.
at a different shop !
To re-boot that computer ECM/TCM all one must do is, remove the Negative cable from the Chassis battery. leave it off a few minutes and then replace it. I'd do it three times just to be sure it took.
When you start driving the coach again, it will require about 1500 miles for the computer to learn your driving habits, and return to normal.
Our's is a Alison 6000 I'm hoping your 3000 is the same procedure.
38,782 PostsLatest Activity: Sep 10, 2026
