toornotto's avatar
toornotto
allisson transmisson
Allison transmission md3060 key pad after starting engine, the transmission will not engage when I touch the key pad for drive or reverse unless I hold the key pad for about 5 to 10 seconds then it will engage and operate normally, but will not shift into neutral when I stop
  • I can't help you, but we had a problem once with our Allison suddenly going in and staying in limp mode. CAlled just about everybody and then decided to call Allison. A very knowledgeable tech (and not faraway) walked DH through a temp fix and then we drove it to the closest Allison center. There the same tech made the repair (had to replace a wiring harness) and we were on our way. It was still under warranty.
    The guy knew exactly what was wrong by our description. Save yourself some time and effort. . . call Allison.
    Dale
  • I've never heard of this problem but I'm gonna venture a guess that it will turn out to be the keypad. Just a guess.
