One warning - Allure is very affected by temperature change. It MUST be able to "move" as it changes. RV's traveling, in storage, or even experiencing daily temperature swings may have some buckling.
Also, I have found the top surface of the two Allure patterns I chose to be very affected by scratching - these are not wear-free. The darker pattern shows the scratching easily while Country Oak shows none. Plus, I had two pieces with substantial lumps in the planks - very noticeable when you step on them, and probably very noticeable as they wear. Inspect EACH PLANK before you put it down!
