JRscooby wrote:
Horsedoc wrote:
JRscooby wrote:
Warning! Drilling is not hard, but it will heat a bit to the point it can not be sharpened. I ground a dull point on a piece of half inch all-thread about a foot long, put a piece of PCV pipe between nuts on the other end. Lay the flap on 2Xs with a gap where you want the hole. Heat the point, and shove it thru the flap, nice round hole for the 3/8 bolt.
What? Synthetic rubber hard enough to heat and ruin a drill bit?  Really?
  Yes, the good flaps are about half inch thick. After the cut, the rubber has more friction on the bit than steel. A half inch bit will leave a hole that fits tight on a 3/8 bolt.
 You can use or ignore what I say, cost me the same. But I have mounted a lot of mudflaps in about 35 years of working trucks.
Wow, never would've thought that rubber from mud flaps could heat a drill bit up like this!
Thanks for the heads up, JRScooby.  Your solution there seems a bit extreme, seems like you'd have to get that piece of all-thread awfully hot to be able to shove it through and cut the hole in the rubber!  Not sure I'm going to try that.  I think instead, I'll just find an old drill bit I'm not too worried about losing, and use that.  I have tons of old drill bits laying around.
Will
