Doug is trying to tell you something in his post.
IF plugged into shoreline and the engine is running this is a common/normal event.
Under certain circumstances the generator can cause the same symptoms.
Even strong solar panels can cause the system to alarm but is much more rare.
In any case the first thing is to put a voltmeter across the batteries to see what the voltage is running.
