oly1946
Oct 13, 2013Explorer
alternater light
I have a Monaco Camelot 40ft motorhome the alternater light will not go out, I have put new one on the light still stays on also new batterys
dougrainer wrote:oly1946 wrote:
no the alternater is not showing a charge,the mechanic says it is in the starter relay what and where is the relay you are talking about
The Starter relay?????? Find another mechanic. It is NOT the starter relay. 2 things only. 1. The Alternator is bad or the Voltage Regulator. 2. Some Alternators have the voltage regulator built in. Not sure about Monaco Roadmaster Chassis which is which. Doug
