Chum_lee
Mar 22, 2017Explorer
On most modern alternators there's not much to rebuild. Either the housing, pulley, and fan are serviceable, or they are not. Same for the rotor and stator. They are generally not repaired, just cleaned and resealed, or replaced. If not too worn, the slip rings on the rotor can be turned smooth on a lathe and reused. The brushes, bearings, and voltage regulator are usually replaced, but not necessarily so on "white box" budget rebuilds.
All bets are off with the latest generation alternators (not yours) which are electronically output controlled by the ECU.
You can usually buy a new unit, a rebuilt unit, or repair your own based on your budget, location, and what you are comfortable working with.
Chum lee
Chum lee
