danwes's avatar
danwes
Alternator or isolator.?
2002 Winnebago, ultimate advantage. 40e. 350 Cummings. Alternator stopped charging. Both sets of battery's. Shore power or generator will charge both sets of battery's. How do I determined which is at fault. Isolator or alternator? Thanks Dan.
  • I doubt whether you have an isolator. You may have a regulator.
    Check the alternator large terminal for 12+ volts output.
  • Maybe both?
    When you have no charging from engine at all, it has to be alternator.
    When chassis battery gets power via insulator , the insulator is defective.
