dan-nickie
Sep 10, 2014Explorer
sloman2001 wrote:
I have weighed my MH, it is actual 11,340 lbs front (12,350 maximum), and 19,040 (20,000 maximum) on the rear axle with dual tires.
I have the designated tires as shown below and got this chart from the Michelin website. I am dividing the actual front tire weight by 2 ( 11,340 / 2 = 5,670 lbs ). Using the chart, the front tires should be inflated to at least 100 lbs, while the rear tires ( 19,040 / 2 = 9,520 lbs ) should be 90 lbs psi.
Having said all that, is that what all of you would do, or would you add extra psi and slightly overinflate? Sorry, I am new at this.
275/80R22.5 LRG
75 80 85 90 95 100 105 110
Single 4725 4940 5155 5370 5510 5780 5980 6175
Dual 8600 9080 9380 9770 10140 10520 10880 11350
Thanks, Tom
PS. I hope this table posts OK, or it will be hard to read. There does not seem to be a preview option.
Looks like you have a handle on it.
BTW, your pressures of 100 front, 90 rear seems to be a pretty common result after people get their weights.
Many of us add a little since we do not have 4 corner weights.
I went with 105 front and 95 rear after adding 5 lbs for safety.
38,766 PostsLatest Activity: Jan 10, 2026
