RayChez
Sep 14, 2013Explorer
piku wrote:
Is the hydro hot like the aqua hot? Using diesel or electric to do radiant in floor heat? Why? Is it that much more comfortable than 2 forced air furnaces? We will probably be avoiding cold weather by snowbirding, otherwise I would certainly be interested in hunting something like that. Is there something I am missing about that system? The BTU/$ is pretty similar between propane and diesel.
Any diesel pusher will ride better then a F-53 or Workhorse chassis which are gasoline motorhomes.
Your diesel coaches will have air bags. Some have four air bags which are big versus the ten air bag which comes on Monaco high end coaches. The ten air bag will give you a firm stiff ride vs the four air bag coaches. Take a test drive on any coach that you are interested in and you be the judge. Do not believe half of the stuff put out in any forum, some will be biased to what they have even though it is not much better then the next coach.
American Eagle has the Liberty chassis which is one of the best in the market.
I believe the older Newmar coaches had Freighliner XC and some had Spartan chassis. Those two chassis are very similar in ride. Both are very good chassis, you will never wear one out.
And Country coach has their own version. Also a very good chassis.
