Marv Hoag wrote:
willald wrote:
I'm curious, those of you that have done away with LP gas entirely, and say you've gone totally electric: What are you using for heat?
Did you find an electric furnace to replace the LP gas furnace most units come with? Or are you just relying on various stand-alone heaters, that don't use the heat ducts your coach has?
I personally would hate not having ducted heat, would make it really tough to keep entire coach warm in the winter..
that post mentioned he had Aqua hot, which is diesel powered.
Right, Aqua hot is used to heat the water, I got that. I am more curious about what folks are using, to heat the entire coach, what they've replaced the traditional LP furnace with..
Will
