tinkerer
Oct 20, 2014Explorer
It depends on the size of your coach. A bigger coach requires a bigger engine which usually use more fluids and filters. I have a coach with a C7 Cat which holds 5 gallons of oil but change it every 7000 miles. I use synthetic oil at $16.00 a gallon= $80.00 plus a Cat filter at $16.50, I grease the chassis myself, I usually figure about 15000 mile to change the fuel filter which is about $26.00. Then a diesel with air brakes have a air dryer filter which I run for 3 years, which is about $180.00 Some of these things probably could probably go longer but don't like to have problems on the road. tires are going to be higher for a DP as they generally are larger and have a higher rating. I couldn't tell for a gasser as I have never owned one.:)
38,782 PostsLatest Activity: Sep 10, 2026
