DustyRooster
Oct 16, 2018Explorer
blawless wrote:
I know this sounds off but you didn't mention if you checked the fuses..? I have two, one inside 10amp and a second in the main panel by the engine.
Thanks for the reply, Blaw
My owners manual does not have a specific fuse for "cruise" but I did literally check every fuse, and all are good.
One thing I found interesting, not sure its related, but none of my backlights work (instrument panel illuminates fine). The cruise control switches, headlight switch, hazard switch do not illuminate. Not sure this is normal for an RV or has anything to do with the cruise. Just something else I noticed.
38,768 PostsLatest Activity: Nov 21, 2015
