tderonne
Oct 16, 2018Explorer
I have fixed a few problems with mine.
This thread has the wiring diagrams.
The cruise module/servo has seven wires going to it. It's mounted near the top of the radiator on the driver's side. Fairly easy to unplug and check each wire for proper function with the diagrams.
And the neither the headlight or cruise switches, or the cruise indicator light up, stock. You can't run the self test mentioned in the FTE thread, without an indicator light. But you can hook it up and the self test will run.
38,768 PostsLatest Activity: Nov 21, 2015
