theoldwizard1
Oct 17, 2018Explorer II
vjstangelo wrote:
I didn’t see this mentioned: on my 2011 F53 turning on the hazard lights (emergency flashers) disengages the cruise. Maybe exercise the hazard switch to make sure no issues there.
Somewhere around that time, Ford went to a "throttle-by-wire" system. That system has no servo and no control box. With "throttle-by-wire" all of the cruise control functions are controlled inside the PCM.
Also around that time, Ford started using a BCM (they call it a Smart Junction Box, SJB). The SJB could easily interrupt the signal from the steering wheel switches to the PCM to make it look like you have turned off the cruise control.
38,768 PostsLatest Activity: Nov 21, 2015
