DustyRooster
Oct 17, 2018Explorer
tderonne wrote:
Regarding the recall.
Dusty (can we call you that OP?) said he had read old threads and replaced the pressure switch on the master cylinder. Pretty safe to assume he's read about the recall.
And. the recall doesn't apply to 2003 or newer F53s anyway. Dusty probably has a 2004 or 2003 chassis. Yes, it's possible it's a 2002.
Sure good to mention it, and be sure he's checked, but he probably has. Right, Dusty?
Also, Dusty has a ~2004 vintage F53. The cruise system on it is common to 1999 to 2004 F53s. Older F53s has a similar system, but not the same. Newer ones are drive by wire and completely different. Keep that in mind Dusty as you think about your system.
Yes, Dusty is fine :)
I'm quite certain my Chassis is 2004 and I read about the recall and thought I'd replace my pressure switch first since it was a cheap and easy "fix" that I read helped a lot of others.
The post below yours mentions a "Clock Wire"? What is that?
38,768 PostsLatest Activity: Nov 21, 2015
