DustyRooster
Oct 19, 2018Explorer
PursuitInsight wrote:DustyRooster wrote:PursuitInsight wrote:
When my f53 2003 monaco lapalma had a cruise not working issue, it was the cruise control module connector partially disconnected. I put in a tyerap to prevent disconnection. The side that disconnected most, had the horn ground pin disconnected and the horn was also not working
Hi Pursuit!
Where is that module located? (my horn works)
it is on the passener side. inside the house. top left. so it is on the most upper right side of the engin cover.
multiple pins , flat connector. difficult to see.
It's in the doghouse? That's what I'm assuming you meant by "house"?
38,768 PostsLatest Activity: Nov 21, 2015
