DustyRooster
Oct 24, 2018Explorer
Stranger wrote:
I'm gonna suggest replacing the brake light switch at the brake pedal. It's a bear to get to but is usually the culprit.
On my 2001 Bounder (F53) when cruise was active, if we hit a bump, the cruise would cut off but the brake lights would not activate. Tried putting a Bunjee cord on the pedal to hold it up, wasn't the issue.
Put in a new Brake light switch, no more problems.
Just ordered a new switch, its cheap enough to give it a try. I assume this switch is on at or near the brake pedal/steering column?
38,768 PostsLatest Activity: Nov 21, 2015
