crawford
Sep 01, 2019Explorer
DustyRooster wrote:if I can find that servo to see if the connector is loose. can't find one because you don't use vacuum systems all now are controlled by computer. that is why you installed a control module. Many are still stuck in the past with advise.
Hi All!
Sorry for the delayed response but I finally fixed my CC issue! It was in fact the cruise control module, which was at the front most of the motor. Looks like the bracket was bolted to the radiator support. With a lot of patience I managed to get the old one out and re-install a new one and it worked!
I am back in business!
Thanks for all your help!!
DR
38,768 PostsLatest Activity: Nov 21, 2015
