sealevel_ram
Jan 29, 2015Explorer
dougrainer wrote:
1. Have you removed the touch pad to verify that the multipin connector is connected and secure?
2. The touch pad requires Ignition(or acc) power to power it up. Have you checked that source via the online HWH service manual?
3. Your post is unclear. I believe you stated NONE of the LED lights on the touch pad come on regardless of the slide rooms operating. True?
4. There are 2- 12 volt solenoids at the HWH pump mounted on the motor. The primary, which the main battery positive cable connects to is the "power on" solenoid. THAT solenoid is what is activated by turning the key and touch pad on. The 2nd solenoid just activates the pump motor for hydraulic pressure. Do you have the rectangular control box with the clear plastic cover? Have you removed the plastic cover to check the various fuses AND the tightness of the various machine screws that secure the wire terminals on the circuit board?
5. Have you tried pushing the touch pad buttons REALLY HARD? If you have no LED lights at all when the key is ON, then forget this. Older touch pads get bad contacs and you have to push the buttons extremely hard which means you replace the touch pad.
6. The control box does not really control the slide operation, so your control box may be burnt out. Doug
1. Yes, I checked the connections to the pad.
2. I checked the power at the touch pad connector. It is less than one volt. Don't know what it should be.
3. No LED lights come on the touch pad except the "Travel Mode" light when I activate a slide either in or out.
4. Haven't checked the solenoids. The slides work fine.
5. Yes, I push hard. There are no lights coming on the touch pad except the "Travel Mode" light when I activate a slide.
38,782 PostsLatest Activity: Sep 10, 2026
