dougrainer
Jan 30, 2015Nomad
sealevel ram wrote:
Hello Campers,
To those of you following this thread (and care) today I:
Turned the ignition to start as usual. No lights lit up on the pad (original problem) or in the control box (something new today).
Started to do the troubleshooting again from step 1.
Opened the control box (plastic cover). Checking a fuse, I had to move some of the wires in the box, NOT disconnecting anything, just jiggling wire around.
Had lunch.
Turned ignition to start as usual. Touch pad lit up. Control box lit up. Everything appears to be working.
Any more comments? I appreciate all the expertise on this topic. Thanks.
As you stated originally, your problem was intermittent and then it completely failed. You jiggled some wires and it now works. Once you go in transit that loose wiring will jiggle loose again and you will be in the same boat. The multiconnections on the control box are weathertight and have locking tabs to hold them secure. You need to take the Plexiglas cover OFF and tighten the few screw secured ring terminals. Doug
38,782 PostsLatest Activity: Sep 10, 2026
