Archie_Kravitz
Jan 30, 2015Explorer
I had the same problem on my Essex and I found the two 3/4" bolts that come up from the bottom to hold the pump on the frame were loose and that was the motor ground. Luckily it was at night and when I had the wife push the key pad it lit up across the bad ground. Tightened up the bolts and two years, no more problem.
38,782 PostsLatest Activity: Sep 10, 2026
