sealevel_ram
Jan 30, 2015Explorer
dougrainer wrote:
As you stated originally, your problem was intermittent and then it completely failed. You jiggled some wires and it now works. Once you go in transit that loose wiring will jiggle loose again and you will be in the same boat. The multiconnections on the control box are weathertight and have locking tabs to hold them secure. You need to take the Plexiglas cover OFF and tighten the few screw secured ring terminals. Doug
I haven't reinstalled the cover. I will try to secure everything before buttoning it up, if possible.
38,782 PostsLatest Activity: Sep 10, 2026
