Tinstar
Mar 24, 2016Explorer
Another step problem
My Kwikee double steps have started acting weird recently. I've not had a problem with them prior to this. They act like my ignition switch is on all the time (mostly). With the key in the run position, they extend and retract with the door just as they should. When I remove the key, they still extend and retract with the door (door open they extended, door closed they retract) . It's not done this in the past. They have always extended when I open the door and they stay out and don't retract until I turn the ignition back on.
I said they do this all the time (MOSTLY). Every now and then, the steps will stay out with the door closed like it is supposed to do but after an hour or a day, they will automatically retract. I was thinking a bad ground so I crawled under, cleaned the ground and reattached it. I also, worked the powered plug several times in case there might be corrosion in the connection. The last kicker is SEVERAL TIMES, the steps will retract and stay retracted and not work with the door. The only way I can get them to extend is put the key in the ignition and open the door.
I've been trying to find a troubleshooting guide on the web but haven't found a good link yet. I'm open to suggestions for a cure or a good link.
