JeffAHarris's avatar
JeffAHarris
Another WH brake problem
First time poster here, I have lurked and read so much on the w.h. brake problem that I think I have overloaded my brain! 2007 Monaco Monarch, 8.1 chevy 6 speed Allison with 27k miles. 2 years ago in Colorado springs the rear breaks would not release, causing over heating. Made it to springs auto and truck service, great people got us in and did a brake fluid flush. Last fall 5 miles from home I notice the rv didn't want to pull out at a stop light, this time the front brakes were dragging. Go back home bleed brakes, good to go. Last weekend maybe 30 miles from home, noticed it again, this time driver front dragging, after no hard braking! So 4 quarts of fluid and a complete flush I am ready again, but no both front this time. I have removed the caliper on the passenger front, it has the steel pistons, all this reading I have done made me believe the phenolic pistons were the problem. I am heading out west in 3 weeks, I hate to just throw parts at it, but that's where some advice is needed. I am a capable mechanic and have several friends in the parts business so I can get what I need at good prices. THANKS, Jeff
  • Check first to see if the recall work has been performed. Reeder Truck and RV Center, in Knoxville, TN is well known for being able to deal with Workhorse brake issues.
    If you have had the recall done, and the new calipers installed, then perhaps your problem is that the caliper slide surfaces are not properly lubricated which allows the caliper to slide easily.
