dougrainer
Aug 02, 2013Nomad
Tiffin uses the round antenna. You either have the hand held wired remote or the IR remote control. At the antenna hook up plate in the overhead above the dash right hand cabinet you MUST push the black button on that wall plate and the green lite will come on. You also MUST put each TV into Antenna(air) mode in each TV's set up. You have 2 choices---CABLE or Antenna. If you had Cable at the Campground then the TV's were set on Cable and you have to reset each TV to Antenna now and then do a channel programming. Inside your Tiffin owners packet should be a paper outlining what I just posted. Doug
38,769 PostsLatest Activity: Apr 03, 2026
