wa8yxm
Aug 02, 2013Explorer III
You need to make sure your TV knows it is hooked to cable, This is normally a menu setting, In your RV there is either a wall plate with a switch, Light 12 volt outlet and antenna connection, Light must be on
A box of many buttons, Power must be on and ANT sellected
Or a Sensar Pro (Wall plate with 3 buttons, several lights, and two digital displays) which must be in any mote other than CABLE. Tap the top left button to check the mode it's in.
38,769 PostsLatest Activity: Apr 04, 2026
