In my experience, using the crank-up bat wing antenna with the Wingman UHF add-on, I can only pickup stations with-in about 30 or 40 miles. Make sure your TV is searching for digital signals when you scan. And double check you selected the correct input on your TV...most of the newer sets have multiple input connectors and you must select the right one or it won't find anything. Also, rotate the antenna to different headings before doing a scan. As mentioned, once you find one digital station you should be able to use a direction meter in the TV to peak that signal.
