wa8yxm wrote:
If the TV fades out when you turn on a 12 volt something then one of several issues exist... ONE: your 12 volt somethng is plugged into the antenna wall plate.. BAD IDEA, plug it in elsewhere..
In this case the current draw of your 12 volt device is lowering the voltage enough that the amplifer says "I give up".
2: Very bad wiring in RV, (M
That outlet might be good for a voltage monitor or a "night light" (I have a nice 12 volt night light, picture on it, Cigarette with bar-sinister on top of it, nivesal NO SMOKING sign) but not much of anything more.
Get your 12 volts for device elsewhere and see if that helps.
I do think that there is a draw on the 12 volt system there causing the drop out I do think the wiring is to small for the load.
JimR
