smlranger
Feb 07, 2016Explorer
Had a Winnebago Journey 36' on XC chassis for 8 years. For sure check all the basic stuff like correct ride height, tire pressure, condition of shocks.
I installed a Safe T Steer stabilizer on the front and Super Steer Motion Control Units on each of the four air bags. The MCU's made a remarkable difference in handling.... reduced Walmart Wobble, less leaning in corners, just a much more stable ride. I believe there are other companies making similar devices but the Supersteer units were what was available at that time.
As noted if your end link bushings and your front sway bar bushings are rubber, they may be hard. Replacing them with the urethane bushings will also help.
